Group: DynoMotion Message: 460 From: Ross Ferguson Date: 6/20/2010
Subject: Re: Lathe - Mill confusion
Thanks Bengt,
I did that, and the tweaks that Tom suggested, and all is well now :)
Ross
On 17/06/2010 11:20 PM, Bengt Sjölund wrote:
Hi Ross,
start with your lathe profile, go into ports and pins in config.
set axis X and Z disable Y - copy your Y settings to Z SAVE
Restart Mach3 and you should be OK, are you using the lathe 1024.lset screen? Cheers Bengt
--- In DynoMotion@yahoogroups.com, "fermanz" <ferman@...> wrote:
> I have the lathe controls all working correctly but I have a bit of a problem with Mach3 coming up with Dynomotion Status - Z axis disabled.
> I must admit that when I first started Mach3, for this machine, I created a profile and I was sure that was a turning profile but I got a mill screen up and, as we were only looking to see if the DROs worked, at that stage, I left it that way for the trial.
> The DROs worked perfectly on the X and Y axes, with the Y axes reacting to the Z input.
> I changed the profile to a MachTurn and now Mach3 tells me that the Z axis is disabled, although it is working okay.
> The DROs still seem to be reading as the had in the milling interface, with the X axis DRO reading the Z axis handwheel movement.
> I can get no readout on the X axis DRO although both axes are responding to their handwheel encoders correctly.
> Z is Channel 0 and X is Channel 1 and they work correctly in KMotion.
> Is it possible that there is a Mach3 file that has remembered the original mill format and just carried it over to the turning profile?
> If I delete both mill and turn xml files will they regenerate?
> Ross
Ferguson Windmills Company
835 Old North Road,
R.D.2,    Waimauku,
New Zealand.  0882
Ph 64 9  411 8332       Mobile 027 282 7689
Fax 64 9 412 8655
E-mail   -  ferman@...
http://www.windmills.co.nz
Group: DynoMotion Message: 452 From: fermanz Date: 6/17/2010
Subject: Lathe - Mill confusion
Ross
Group: DynoMotion Message: 453 From: Bengt Sjölund Date: 6/17/2010
Hi Ross,
> Ross
Group: DynoMotion Message: 454 From: Tom Kerekes Date: 6/17/2010
Hi Ross,
Besides that make sure your Coordinate System in KFlop is set up as X=Axis1, Y=unused, Z=Axis0, A=unused with
 DefineCoordSystem(1,-1,0,-1);
